NetGear WNDA3100-200PES N600 Wireless Dual Band USB Adapter
£23.22
Delivery:
Key features
  • Delivers consistent wireless connections using Dual Band Wireless-N
  • Provides enough bandwidth to support music downloads, file sharing and HD multimedia applications
  • Works with all new Wireless-N Gateways, Routers and Access Points
  • Backward compatible with older Wireless-G hotspots
  • Designed for your notebook or desktop PC
Product codes
Plug & Play. Surf & Stream.
NETGEAR Wireless Adapters for high performance are the ideal for fastest downloads and high performance Internet gaming. The High Performance adapters are designed to avoid interference and come with Push `N' Connect push button security.
The NETGEAR N600 Wireless Dual Band USB Adapter wirelessly connects your Windows®-based laptop or desktop computer to a Wireless-N network for demanding applications, such as streaming HD video and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the greatest range, and compatibility with Wireless-G networks allows hassle-free connection flexiblity. Easy setup with NETGEAR® genie gets you up and running fast, while Push 'N' Connect gives you a secured connection at the push of a button.
Dual band avoids interference for reliable connections
Faster WiFi speeds 300/300 - Up to 600 Mbps
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
Product Description NETGEAR RangeMax WNDA3100 - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 3 cm x 9.5 cm x 1.5 cm
Weight 22 g
Localisation Europe
Data Link Protocol 802.11a, 802.11b/g/n
Frequency Band 2.4 GHz, 5 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
System Requirements Microsoft Windows Vista (64-bit versions), Microsoft Windows Vista / XP
Microsoft Certification Compatible with Windows 7
SAR 1.64 W/kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear WNDA3100-200PE...
£23.22
