Nokia 5.1 16GB 5.5" HD+ Display - Blue
£144.00
Colours:
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Durable aluminum uniKeySellingPoints design
  • Full HD+ 5.5'' IPS display with 18:9 ratio
  • 16 MP auto-focus rear camera
  • 8 MP front camera with an 84.6° field of view
  • Operating system: Android
  • Model: 5.1
  • Screen Size: 5.5in
  • Rear Camera: 16 Megapixel
  • Mobile Connectivity: 4G
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £147.49
Save £1.50
Nokia 5.1
A timeless classic refined
Premium craftmanship
Sculpted from a single block of aluminum, the new Nokia 5 goes through a precise machining process to achieve its refined look. From the beautifully rounded corners to the perfect way it fits in your hand, every detail shows a dedication to high-quality craftmanship.
Bigger screen, higher resolution
The upgraded Nokia 5 has a big Full HD+ 5.5’’ IPS display with an 18:9 ratio that’s ideal for watching videos, browsing and gaming. And the higher resolution ensures the content looks sharper as well as bigger.
Group selfies made easy
The new Nokia 5 features a 16 MP main camera with phase detection auto-focus, a faster and more reliable auto-focus system that lets you capture every detail. And the 8 MP front camera is equipped with an 84.6° field of view that fits the whole party in the same frame
Customized performance
The 2.0 GHz Octa-Core processor in the new Nokia 5 runs smoothly whether you’re messaging, browsing, gaming or switching between all three.
The best of Android™, latest innovation from Google
Android One brings a Google designed software experience to the new Nokia 5. Get everything you want and nothing you don’t with a streamlined, easy to use interface and a curated set of pre-installed apps, and free, unlimited high quality photos storage2 with Google Photos. Regular security updates and two years of OS upgrades means the new Nokia 5 with Android One stays secure and features the latest Google innovations like being optimized for the Google Assistant.
What's in the box
Your new Nokia 5.1
5V/2A charger
Micro USB cable
Quick guide
SIM door key
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Product Description Nokia 5.1 - Android One - tempered blue - 4G - 16 GB - GSM - smartphone
Product Type Smartphone 4G
Display LCD display - 5.5" - 18:9 - IPS - Corning Gorilla Glass 3 (scratch resistant glass)
Features Rear-facing camera, front-facing camera
Processor MediaTek Helio P18 MT6755S / 2 GHz (8-core) - 64-bit
Memory 16 GB RAM 2 GB
Supported Memory Card microSDXC slot - up to 128 GB
Operating System Android Oreo
Rear Camera 16 Megapixel focus: automatic
Front Camera 8 Megapixel - focus free
Service Provider Not specified
SIM Card Qty Single-SIM
Wireless Interface Wi-Fi, Bluetooth
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, Micro-USB
Talk Time Up to 1140 minutes
Standby Time Up to 588 hours
Colour Tempered blue
Dimensions (WxDxH) 70.73 mm x 8.27 mm x 151.1 mm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Nokia 5.1 16GB 5.5" HD...
£144.00
