Optoma 3500 ANSI WXGA UST Projector
£1,173.33
Delivery:
Standard: 1-3 working days
Key features
  • Ultra short throw lens (0.36:1 throw ratio) helps eliminate shadows on the screen along with projected light in the presenter's eyes created by traditional front projection systems
  • Comprehensive input/output panel, including dual HDMI, VGA and a microphone input
  • ECO Mode technology helps extend lamp life and lowers power consumption
  • Horizontal & Vertical Keystone adjustment or Cornerstone Correction ensures the image will fill the screen every time
  • Remote monitoring and control of projector over network saves IT employee time and reduces costs related to projector operation
  • Type: WXGA projector
  • Brightness: 3500ANSI lumens
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
NEC's UM351W is a 3500-lumen ultra-short throw projector that packs a multitude of features while delivering an extremely short throw distance for education and corporate applications. With its ability to be mounted to the wall directly above the screen on which it projects, this model helps eliminate the shadows and glare typically found with standard projection systems. The UM351W includes a powerful 20W speaker, closed captioning and RJ-45 for remote management over a network, and its input panel includes dual HDMI, VGA and a microphone input to amplify the presenter's voice.
Product Description NEC UM351W - LCD projector - ultra short-throw - LAN
Device Type LCD projector - 720p
Built-in Devices Speaker
Brightness 3500 ANSI lumens
Contrast Ratio 4000:1
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Lens Ultra short-throw lens
Bulb type 255 Watt
Bulb life cycle Up to 3800 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 344 Watt
Dimensions (WxDxH) 37.8 cm x 42.8 cm x 11.2 cm
Weight 5.6 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma 3500 ANSI WXGA...
£1,173.33
