Optoma 5500 ANSI Lumens Full HD DLP Technology Installation 5...
Optoma 5500 ANSI Lumens Full HD DLP Technology Installation 5.9Kg
£2,153.41
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • High contrast
  • Full 3D
  • Full HD
  • Integrated speaker
  • Energy saving
  • Auto power off
  • Eco AV mute
  • Four-corner adjustment
  • Brightness matching
  • Large zoom range
  • MHL
  • Networking and control
  • BrilliantColor technology
  • Wired remote
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
Delivering Full HD image quality, the EH515 is ideal for conference rooms, large classrooms, lecture theaters, museums and houses of worship. This large venue projector boasts a brightness of 5,500 lumens and features multiple digital connection options, with two HDMI inputs and DisplayPort. For more complex installations, this projector is equipped with a large zoom range, lens shift and a built-in geometric adjustment feature - ideal for image stacking, uneven walls or where a projector placement is awkward and needs to be installed at an angle.
Product Description Optoma EH515 - DLP projector - 3D
Device Type DLP projector - 1080p
3D Capable Yes (3D glasses sold separately)
Brightness 5500 ANSI lumens
Contrast Ratio 10000:1
Resolution Full HD (1920 x 1080)
Native Aspect Ratio 16:9
Lens Shift Direction Horizontal, vertical
Bulb type 365 Watt
Bulb life cycle Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Video Modes 480p, 720p, 1080i, 1080p, 480i, 525i, 525p, 625p, 625i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 425 Watt
Dimensions (WxDxH) 42.4 cm x 34.4 cm x 16 cm
Weight 5.9 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma 5500 ANSI Lumen...
£2,153.41
