Optoma Beige Ceiling Mount with Pole
£69.04
Delivery:
Standard: 1-3 working days
Key features
  • Easy to install - great flexibility and adaptability
  • Quick projector reconnect/disconnect
  • Adjustable height
  • Cable routing for a clean look
Product codes
The OCM815W universal projector pole mount is ideal for high ceilings. Easy to set up with its unique design gives you everything you need for quick adjustment, the flexibility to fit almost any projector and hassle free projector maintenance. It's the perfect universal projector pole mount.
Optoma OCM815W - mounting kit
Mounting kit - ceiling mountable
Mounting Components
Pole mount
Adjustable Height
57.5-82.5 cm
Adjustments
Pitch
Recommended Use
Projector
Max Load Weight
15 kg
White
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma Beige Ceiling M...
£69.04
