The EH415ST is designed for delivering superior quality presentations in classrooms, small meeting rooms or training rooms. This full HD 1080p projector offers stunning image performance from a short distance. It also boasts a brightness rating of 3,500 ANSI lumens, which is ideal for use without dimming the lights.
The projector can be managed and monitored remotely with Crestron RoomView, Telnet, Extron IP Link, AMX and PJ-Link, which allow almost all aspects of the EH415ST to be controlled across a network.
The EH415ST's impressively long lamp life and energy-saving features both contribute to a low overall cost of ownership.
Product Description | Optoma EH415ST - DLP projector - short-throw - 3D | Device Type | DLP projector - 1080p | 3D Capable | Yes (3D glasses sold separately) | Bundled Services | 3 years Optoma Express Service | Microdisplay | DarkChip 3 | Brightness | 3500 lumens | Contrast Ratio | 15000:1 | Resolution | Full HD (1920 x 1080) | Native Aspect Ratio | 16:9 | Colour Support | 1.07 billion colours | Lens | Short-throw fixed lens | Bulb type | 280 Watt | Bulb life cycle | Up to 3000 hour(s) - normal mode , Up to 7000 hour(s) - Eco+ mode , Up to 4000 hour(s) - economic mode | Video Input | RGB, S-Video, composite video, component video (NTSC, SECAM, PAL) | Video Modes | 480p, 720p, 1080i, 1080p, 480i, 576i, 576p | Speakers | Speaker(s) - integrated | Power | AC 120/230 V (50/60 Hz) | Power Consumption Operational | 290 Watt | Dimensions (WxDxH) | 28.6 cm x 26.6 cm x 12.4 cm | Weight | 3.4 kg | Manufacturer Warranty | 3-year warranty |
General | |
Projector | |
Image Size | 150 cm - 386 cm |
Projection Distance | 0.66 m - 1.69 m |
Throw Ratio | 0.50:1 |
Uniformity | 85 % |
Digital Zoom Factor | 2x |
Resolution | Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized) |
Max Sync Rate (V x H) | 120 Hz x 91 kHz |
OSD Languages | Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian |
Features | BrilliantColor, PJlink, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Eco+ technology |
Lens | |
Type | Short-throw fixed lens |
Lens Aperture | F/2.87 |
Keystone Correction Direction | Vertical |
Vertical Keystone Correction | -20 / +20 |
Video Input | |
TV System | NTSC, SECAM, PAL |
Analogue video Signal | RGB, S-Video, composite video, component video |
Video Interfaces | HDMI, component video, composite video, S-Video, RGB |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 10 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 2 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (management) |
Miscellaneous | |
Included Accessories | Carrying case, wireless remote control |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS |
Power | |
Nominal Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Width | 28.6 cm |
Depth | 26.6 cm |
Height | 12.4 cm |
Weight | 3.4 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - lamp - 1 year |
Environmental Parameters | |
Sound Emission (Economic Mode) | 35 dB |
