Optoma Panoview DS-3100PMG Manual Pull Down Projection Screen...
Optoma Panoview DS-3100PMG Manual Pull Down Projection Screen 4:3 100"
£199.99
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Easy to operate and reflects vivid and colorful images
  • Applicable for education venues, meeting rooms, control rooms, boardrooms, training facilities and home theaters
  • Specially suited for specific use projectors
Product codes
The metal casing is compact and elegant. The white cover is coated with PVC technology that enhances the feel and esthetics.
The matte white material provides different brightness and viewing ranges, flexible to suit every setting. The matted white allows a wider view range and soft colors.
It is suited for various venues such as education facilities, home theaters, boardrooms, or other entertainment sites.
Optoma Panoview Pull Down Manual DS-3100PMG+ - projection screen - 100 in (254 cm)
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
Projection Screen Image Diagonal Size
100 in (254 cm)
Projection Image Size
203 cm x 152 cm
Aspect Ratio
4:3
Screen Surface
Matte White
223 cm
11.6 kg
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma Panoview DS-310...
£199.99
