Optoma Universal Projector Ceiling Pole Mount
£69.04
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easy to install - great flexibility and adaptability
  • Quick projector reconnect/disconnect
  • Wall mount capability
  • Adjustable height
  • Cable routing for a clean look
  • Type: [N/A]
  • Brightness: [N/A]
  • Contrast Ratio: [N/A]
  • Portability: [N/A]
  • Resolution: [N/A]
Product codes
The OCM815B universal projector pole mount is ideal for high ceilings. Easy to set up with its unique design gives you everything you need for quick adjustment, the flexibility to fit almost any projector and hassle free projector maintenance. It's the perfect universal projector pole mount.
Product Description Optoma OCM815B - mounting kit
Product Type Mounting kit - ceiling mountable
Mounting Components Pole mount
Adjustable Height 57.5-82.5 cm
Adjustments Pitch
Recommended Use Projector
Max Load Weight 15 kg
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma Universal Proje...
£69.04
