General |
Device Type |
DLP projector - 720p |
3D Capable |
Yes (3D glasses sold separately) |
Built-in Devices |
Speaker |
Networking |
Ethernet |
Projector |
Microdisplay |
DarkChip 3 |
Brightness |
3300 ANSI lumens |
Contrast Ratio |
18000:1 |
Image Size |
216 cm - 292 cm |
Projection Distance |
0.49 m - 0.66 m |
Throw Ratio |
0.27:1 |
Uniformity |
85 % |
Resolution |
WXGA - WXGA (1280 x 800) |
Native Aspect Ratio |
16:10 |
Colour Support |
1.07 billion colours |
Max Sync Rate (V x H) |
85 Hz x 91.1 kHz |
Bulb type |
190 Watt |
Bulb life cycle |
Up to 4500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode |
OSD Languages |
Danish, Hungarian, Czech, Thai, Slovak, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean |
Features |
BrilliantColor, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, PJlink, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Auto Power Off, Eco+ technology |
Lens |
Type |
Ultra short-throw fixed lens |
Lens Aperture |
F/2.4 |
Keystone Correction Direction |
Vertical |
Vertical Keystone Correction |
-20 / +20 |
Video Input |
TV System |
PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC |
Analogue video Signal |
RGB, composite video |
Video Interfaces |
VGA, HDMI, composite video |
Video Modes |
480p, 720p, 1080i, 480i, 576i, 576p |
Speakers |
Type |
Integrated |
Sound Output Mode |
Mono |
Output Power / Channel |
16 Watt |
Speakers |
1 x mixed channel |
Expansion / Connectivity |
Interfaces |
2 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x USB , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB (power only) - 4 pin USB Type A (power only) , 1 x 3D Sync out |
Miscellaneous |
Included Accessories |
Wireless remote control |
Cables Included |
1 x VGA cable |
Security Features |
Security lock slot (cable lock sold separately), password protection, security bar |
Security Slot Type |
Kensington security slot |
Compliant Standards |
RoHS |
Power |
Power Source |
AC |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
235 Watt |
Power Consumption Stand by |
0.5 Watt |
Dimensions & Weight |
Width |
38.5 cm |
Depth |
31 cm |
Height |
12 cm |
Environmental Parameters |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
0 - 85% |
Sound Emission (Economic Mode) |
26 dB |
