Optoma W319USTir WXGA Ultra-Short Throw Pen Inc Wall Mount
£1,428.91
Delivery:
Key features
  • Ultra short throw
  • High contrast
  • Full 3D
  • Integrated speaker
  • Eco+
  • Energy saving
Product codes
The W319USTir, is perfect for businesses, schools and colleges. It is bright (3300 lumens) and uses IR interactive technology, enabling people to work simultaneously on the screen using a pen. The throw ratio of 0.27:1 means that it can project a 100" image from less than 24 inches away. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter.
It provides a complete package for engaging learning with many features, including two HDMI inputs, powered USB port, powerful 16-Watt built-in speaker, improved lamp life, compact chassis and a completely mounting system for a fast and simple set-up.
Product Description Optoma W319USTir - DLP projector - ultra short-throw - 3D
Device Type DLP projector
3D Capable Yes (3D glasses sold separately)
Built-in Devices Speaker
Microdisplay DMD Chip
Brightness 3300 ANSI lumens
Contrast Ratio 18000:1
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Lens Ultra short-throw fixed lens
Bulb type 190 Watt
Bulb life cycle Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes 480p, 720p, 1080i, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 235 Watt
Dimensions (WxDxH) 38.5 cm x 31 cm x 12 cm
Weight 4.63 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma W319USTir WXGA...
£1,428.91
