Optoma White Flush Universal Mount
£69.99
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easy to install
  • Great flexibility and adaptability
  • Quick projector reconnect/disconnect
  • 70 mm horizontal shift
  • Adaptable to different projectors
  • Accessory Type: Mount
  • Stock Status: In Stock
Product codes
The OCM818W-RU white universal projector flush mount is suitable for installation in the office or at home. Easy to set up with its unique low-profile design gives you everything you need for quick adjustment, the flexibility to fit almost any projector and hassle free projector maintenance. It's the perfect universal projector flush mount.
Product Description Optoma OCM818W-RU - ceiling mount
Product Type Ceiling mount
Adjustments Roll, pitch
Recommended Use Projector
Max Load Weight 15 kg
Colour White
Designed For Optoma DH1015, DH7, DS327, DS329, DS5, DX327, DX329, ES550, ES551, ES556, EW1691, EW556, EW615, EW631, EW762, EX550, EX551, EX555, EX556, EX631, EX784, FW5200, FX5200, GT750, HD23, HD230, HD300, HD33, HD3300, HD600, HD6720, HD8300; GameTime GT750; ProScene EH2060; ThemeScene HD23, HD230, HD33, HD83
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma White Flush Uni...
£69.99
