Optoma X319UST XGA Ultra-Short Throw Projector Inc Wall Mount
Key features
  • Ultra short throw
  • High contrast
  • Full 3D
  • Integrated speaker
  • Energy saving
  • Quick resume
  • Auto Power Off feature
Product codes
The X319UST, is perfect for businesses, schools and colleges. It is bright and its throw ratio means that it can project a 100" image from shorter distance. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter. It provides a complete package for engaging learning with many features, including two HDMI inputs, powered USB port, powerful built-in speaker, improved lamp life, compact chassis and a handy mounting system for a fast and simple set-up.
Optoma X319UST - DLP projector - ultra short-throw - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DMD Chip
Brightness
3200 ANSI lumens
Contrast Ratio
18000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Lens
Ultra short-throw fixed lens
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
235 Watt
38.5 cm x 31 cm x 9.9 cm
4.57 kg
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma X319UST XGA Ult...
