Optoma X319USTir XGA Ultra-Short Throw Pen Inc Wall Mount
Key features
  • IR pen interactive technology
  • XGA resolution
  • Large shadow-free images from a short distance
  • Powerful built-in speaker
  • Multiple connections including two HDMI inputs, RJ-45 control and monitoring
Product codes
The X319USTir, is perfect for businesses, schools and colleges. It is bright and uses IR interactive technology, enabling people to work simultaneously on the screen using pens. The high throw ratio means that it can project images from a small distance. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter.
Product Description Optoma X319USTIR - DLP projector - ultra short-throw - 3D
Device Type DLP projector
3D Capable Yes (3D glasses sold separately)
Built-in Devices Speaker
Microdisplay DMD Chip
Brightness 3200 ANSI lumens
Contrast Ratio 18000:1
Resolution XGA (1024 x 768)
Native Aspect Ratio 4:3
Colour Support 1.07 billion colours
Lens Ultra short-throw fixed lens
Bulb type 190 Watt
Bulb life cycle Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes 480p, 720p, 1080i, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 235 Watt
Dimensions (WxDxH) 38.5 cm x 31 cm x 9.9 cm
Weight 4.63 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma X319USTir XGA U...
