OtterBox Defender Series Samsung Galaxy Tab 4 (10.1 in)
£51.51
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Two-piece polycarbonate inner shell provides cushioning for the Galaxy Tab inside this Galaxy Tab 4 10-inch case
  • Built-in screen protector guards against scratches and smudges to the touchscreen
  • Outer slip cover wraps around the inner shell to absorb impact and deflect shock when your device slips out of hand
  • Port covers help keep dust and debris out of your Galaxy's ports and jacks
  • Case allows for full access to all Galaxy Tab 4 10.1 features and functions
  • Multi-layer case includes a polycarbonate shell, built-in screen protector, outer slip covers and shield stand
  • Colour: Black
  • Stock Status: In Stock, Used Stock
Product codes
Defender Series for Galaxy Tab 4 10.1 provides the tough, rugged protection you have come to know and trust from OtterBox. Designed to withstand drops, bumps and dust so you can be worry-free at work and at home. The precision fit of the Defender Series is built for uninhibited use of all your Galaxy Tab 4 functions. The included shield stand provides an extra layer of protection on the go and transforms into a stand for easy typing and viewing.
Product Description OtterBox Defender Series Samsung Galaxy Tab 4 (10.1 in) - protective case for tablet
Product Type Protective case for tablet
Screen Size Compatibility 10.1"
Material Polycarbonate, synthetic rubber
Colour Black
Manufacturer Warranty 1-year warranty
Designed For Samsung Galaxy Tab 4 (10.1 in)
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
This item has been opened. The packaging is damaged.
Ref: 9T40 037381
£6.64
product
Ref: 9T40 037381
Accessories
Packaging
Functional
Software
Manuals
£6.64
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
OtterBox Defender Seri...
£51.51
