OtterBox Galaxy S20/Galaxy S20 5G Symmetry Series Clear Case
£29.98
20 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Thin profile slips easily into tight pockets
  • Durable protection defends against drops, bumps and fumbles
  • Raised screen bumpers help protect your display
  • One-piece design pops on and off in a flash
  • Device Type: Smartphone
  • Type: Case / Cover
  • Product Range: OtterBox
  • Product Model: Samsung GALAXY S20
Product codes
Show off your phone with the slim profile of Symmetry Series Clear, the clear Galaxy S20 case that coordinates with any look. Fortified with drop protection and easy to install, Symmetry Series Clear is designed so your phone's features work just like you expect. It's style that's ready to grab and go wherever the day takes you.
Product Description OtterBox Symmetry Series - back cover for mobile phone
Product Type Back cover for mobile phone
Material Polycarbonate, synthetic rubber
Colour Clear
Designed For Samsung Galaxy S20, S20 5G
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use, SCRATCHES ON BACK OF PHONE COVER
Ref: G2MS 046613
£2.44
product
Ref: G2MS 046613
Accessories
Packaging
Functional
Software
Manuals
£2.44
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£29.98
