OtterBox LifeProof LifeActiv 2" Belt Clip
£20.91
Delivery:
Key features
  • Function: mounts your smartphone right where you need it
  • Uses: two-inch clip works with belts, backpacks, hydration packs and purses
  • Profile: the lowest-profile quick-mount belt clip available
  • Adjustable: mounts phone in portrait or landscape positions
  • Security: positive locking switch for added security
  • Compatibility: works with all LifeProof cases and many other brand cases
  • Access: phone mounts with a quick click, and comes off with a simple twist
  • Modular: easy-to-install adhesive adaptor works with all LifeActiv QuickMount accessories
Product codes
The LifeActiv belt clip with QuickMount keeps your phone by your side and quick on the draw. Featuring a 2-inch clip, it attaches to traditional belts, utility belts, backpacks and purses. And the QuickMount holds your phone with a quick click, and lets go with a simple twist. Plus, the sleek design makes it the lowest-profile quick-mount belt clip on the market. LifeActiv includes the easy-to-install adaptor and everything needed to pair your LifeProof or other brand case with the QuickMount. Once the adaptors installed, your phone works with the entire lineup of LifeActiv QuickMount accessories.
LifeProof - belt clip
Belt clip
Intended for
Mobile phone
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
OtterBox LifeProof Lif...
£20.91
