OtterBox Symmetry Duo for Surface Pro (2017) / Pro 4 / Pro 6...
OtterBox Symmetry Duo for Surface Pro (2017) / Pro 4 / Pro 6 - Slate
£36.38
Delivery:
Key features
  • Slim profile
  • Defends tablet and keyboard
  • Allows smooth use of kickstand
  • Colour: Slate grey
  • Stock Status: Used Stock
Product codes
Slim, clear case keeps your tablet safe for peak productivity. Two-piece design protects both your tablet and the keyboard. Slip your tablet into the sleek Symmetry series case and use your tablet everywhere with confidence.
Product Description OtterBox Symmetry Series - flip cover for tablet
Product Type Flip cover for tablet
Material Polycarbonate, synthetic rubber
Colour Slate grey
Designed For Microsoft Surface Pro (Mid 2017), Pro 4, Pro 6
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use. Not in original packaging.
Ref: FCCW 041316
£5.11
product
Ref: FCCW 041316
Accessories
Packaging
Functional
Software
Manuals
£5.11
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
OtterBox Symmetry Duo...
£36.38
