We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
OtterBox Fast Charge Premium wall chargers are engineered rugged and built to outlast. Thoughtfully designed with great mobile expertise and quality that is uniquely durable - these tough wall chargers are designed to work flawlessly together with all OtterBox mobile power solutions - to build trust, foster connections and instill confidence for whatever the day brings.
Product Description | OtterBox Premium power adapter - 24 pin USB-C - 18 Watt | Product Type | Power adapter | Dimensions (WxDxH) | 5.9 cm x 2.9 cm x 6 cm | Weight | 96.5 g | Colour | Black shimmer | Localisation | United Kingdom, Ireland | Output Connector Type | 24 pin USB-C | Voltage Required | AC 100-240 V (50/60 Hz) | Voltage Provided | 5 / 9 V | Max Electric Current | 3 A | Fast Charge Technology | Power Delivery 3.0 | Power Provided | 18 Watt |
General | |
Width | 5.9 cm |
Depth | 2.9 cm |
Height | 6 cm |
Weight | 96.5 g |
Enclosure Colour | Black shimmer |
Power Device | |
Input Connectors | Power Type G |
Input Connectors Qty | 1 |
Output connectors | 24 pin USB-C |
Features | USB Battery Charging 1.2 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
