Panasonic Camcorder Black FHD 2.51MP 50xZoom 3.0LCD WiFi SD/S...
Panasonic Camcorder Black FHD 2.51MP 50xZoom 3.0LCD WiFi SD/SDHC/SDXC
£288.81
Delivery:
Standard: 1-3 working days
Key features
  • 90x intelligent/50x optical zoom
  • 28 mm wide-angle
  • Twin camera function
  • Wireless multi camera
  • HDR (High Dynamic Range) movie
Product codes
Easily capture distant objects that are too far away to shoot with conventional zoom functions - thanks to 90x Intelligent Zoom. You can also use the 50x Optical Zoom to zoom in on your subject to add more emotion and dynamics to your homemade footage. Fit more people and more of the background into the frame - the 28 mm Wide-Angle function (35 mm camera equivalent) makes it possible. This is especially handy when you want to take a group shot in a small room. It fits objects in even when you shoot from up close, and makes it possible to pick up even small sounds with the camcorder's built-in microphone. This model includes a rotatable sub camera that lets you take shots from two angles at once. For example, you can capture the family and a selfie, or both tele and wide-angle shots. A Backup function records a picture in picture image and a main camera image without a sub window for backup. The sub camera image is recorded into any one of various sub windows, and its display position can be changed by touch operation.
Panasonic HC-W580 - camcorder - storage: flash card
Camcorder - 1080p - widescreen
Media Type
Flash card
Memory Card Slot
SD card
Wireless Interface
Wi-Fi
Sensor Resolution
2.51 MP
Effective Sensor Resolution
Video: 2.2 MP - Photo: 2.2 MP
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 50x zoom - 2.06 - 103 mm - f/1.8-4.2
Lens System (2nd)
Lens 2.48 mm - f/2.8
Focus Adjustment
Automatic, manual
Digital Zoom
3000x
Image Stabiliser
Optical (5-axis HYBRID O.I.S. + with Active Mode)
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery - 1940 mAh (included)
Composite video/audio, HDMI, USB 2.0
6 cm x 12.9 cm x 6.2 cm
264 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Panasonic Camcorder Bl...
£288.81
