Panasonic i-Pro Smart Network Camera
Key features
  • 0.32-megapixel high sensitivity MOS sensor
  • Multiple H.264 streams and JPEG streams ensure simultaneous real time monitoring and high resolution recording
  • ABS (Adaptive Black Stretch) technologies deliver wider dynamic range compared with conventional cameras
  • High sensitivity with day and night function
  • VIQS (Variable Image Quality on Specified area) technology allows the designated area to retain higher image quality
  • Digital noise reduction: 3D-DNR ensures noise reduction in various conditions
  • Progressive scan ensures clear images with less motion blur and no tearing even when the subject is moving
  • Superior color reproduction by primary (RGB) color filter VMD (Video Motion Detection)
  • Face detection function detects the position of human face and the information is sent by XML or video stream
  • Alarm sources including VMD and Panasonic alarm command can trigger actions such as FTP image transfer, E-mail notification, indication on browser, and Panasonic alarm protocol output
  • JPEG image compression ratio can be changed by alarm so that higher quality image can be provided
  • Prioritized stream control: one of the video streams can be prioritized when multiple recorders or client PCs are accessing the camera so that the recorder or the client PC can maintain the frame rate
Product codes
Panasonic WV-SF132E.
Placement supported: Indoor & outdoor.
Form factor: Dome.
Colour of product: White.
Mounting type: Wall.
Maximum resolution: 640 x 480 pixels.
Supported video modes: 720p.
Camera shutter speed: 1/8000.
Sensor type: MOS.
Panasonic i-Pro Smart HD WV-SF132E - network surveillance camera
Network surveillance camera - fixed dome
Camera Mount Type
Wall mount, ceiling mount
10 cm x 10 cm x 4.7 cm
200 g
White
Wired
Camera
Colour - Day&Night - PAL
Max Resolution
640 x 480
Frame Rate (max)
30 images per second
Motion Detection
Optical Sensor Type
MOS - 1/5" - 0.32 MP
Minimum Illumination
2 lux - colour - F2.9 - shutter 8/30 sec / AGC High , 1.3 lux - B&W - F2.9 - shutter 8/30 sec / AGC High , 0.3 lux - colour - F2.9 - shutter 8/30 sec / AGC High , 0.16 lux - B&W - F2.9 - shutter 8/30 sec / AGC High
Focal Length Control
Fixed focal
Focal Length
1.95 mm
Lens Iris
F/2.9
Ethernet 10Base-T/100Base-TX
Voltage
DC 48 V / PoE
RGB primary colour filter, digital noise reduction, progressive scanning, e-mail alerts, automatic electronic shutter, Adaptive Black Stretch (ABS), ONVIF support, 3D Noise Reduction Technology, face detection, Electronic light control (ELC), UniPhier LSI platform, Video Motion Detector (VMD), Variable Image Quality on Specified area (VIQS), Video Motion Detection Technology, auto gain control, auto white balance
Environmental Parameters (operating)
0 °C - 40 °C; 0 - 90% (non-condensing) relative humidity
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Panasonic i-Pro Smart...
