Panasonic KX-TGF320E Corded/Cordless Combo with TAM
£63.86
Delivery:
Key features
  • Easy-to-see large tiltable display
  • One-touch dialing buttons
  • Dedicated call block button on the base unit
  • Battery backup for unexpected power failures
  • Reduce unwanted calls such as telemarketers
  • Protect calls
  • Do Not Disturb mode
  • Advanced Answering System
  • Smoothly conduct teleconferences
  • Easily register to the phonebook
Product codes
A dedicated call block button enables you easily register to the call block list. During an electric power failure, the power stored in batteries can be supplied to the base unit. This allows you to make a call with handset even when the power is out. You can block any specified number, as well as any head string of 2 to 8 digits matching your specified numbers or numberless calls. Communications between the cordless handset and base unit are encrypted, and the encryption password is periodically changed to maintain a high level of security.
Panasonic KX-TGF320 - corded/cordless - answering system with caller ID
Corded/cordless answering system with caller ID
Cordless Phone Standard
DECT\GAP
Speakerphone
Call Services
Caller ID, Call Waiting, Call Transfer
Display
LCD display - monochrome - Yes
Display (2nd)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Panasonic KX-TGF320E C...
£63.86
