Panasonic LUMIX DMC-LX5 Camera - Black
CAPTURE TRULY DYNAMIC 24MM WIDE-ANGLE IMAGES
Product codes
Creative Compact Digital Camera LX5 - Featuring High-sensitivity CCD and f/2.0 LEICA DC VARIO-SUMMICRON Lens
The DMC-LX5 packages an f/2.0 LEICA DC VARIO-SUMMICRON lens with 24mm wide-angle and 3.8x optical zoom. This low-distortion, high-resolution lens lets you capture truly dynamic 24mm wide-angle images while rendering the tiniest nuances clearly, from corner to corner. The fully open f/2.0-3.3 aperture and iris diaphragm also work together to produce stunning scenes with gentle soft focusing. The 24mm wide-angle lens captures approx. 213% larger viewing space compared to a normal 35mm lens.
The DMC-LX5 features a large 1/1.63-inch, 10.1-megapixel ultra-sensitive CCD. It achieves high resolution, noise-less pictures even in high sensitivity recording and richly reproduced gradation in highly contrasted situations with the exquisitely wide dynamic range. In addition, the CCD in DMC-LX5 can reproduce images shot with the lens set from 24mm to 90mm in any of three aspect ratios; 4:3, 3:2 or 16:9, so you can always capture dynamic, richly expressive shots with a wide perspective.
With the Intelligent Resolution technology, 3 areas - outlines, detailed texture areas and soft gradation areas - are automatically detected. Apart from the uniform enhancement of sharpness, this technology precisely performs signal processing pixel by pixel in the most effective way according to the area. As a result, images are clear and crisp in both photos and movies. The Intelligent Zoom extends the zoom ratio by approx. 1.3x maintaining the image quality even combining a digital zoom. A 3.8x optical can virtually extend to 5x equivalent.
The DMC-LX5 can record HD movie in AVCHD Lite with high sound quality of Dolby Digital Creator. Motion JPEG format is also available (1,280 x 720 pixels). Just press the Motion Picture Button, and shooting begins. In the Creative Movie Mode, the shutter speed and aperture can be adjusted. The iA Mode can also be activated in motion picture recording. When the DMC-LX5 is connected to a Panasonic VIERA via an optional mini HDMI cable, the TV's remote control unit can be used to enjoy playing back with greater convenience.
The excellent manual controllability is the advantage of DMC-LX5. The jog dial enhances the operability together with the focus switch relocated on the lens barrel. The My Colour Mode and Film Mode make it easy to customize colour effects to match your preference. The DMC-LX5 also features a 3.0-inch LCD with 460,000-dot high resolution and a wide range of optional accessories to choose from to match your shooting situations and style, including view finders, filters and external flashes.
Optics
Camera Effective Pixels 10.1 Megapixels
Sensor Size / Total Pixels / Filter 1/1.63-type / 11.3 Total Megapixels / Primary Color Filter
Aperture F2.0 - 3.3 / Multistage Iris Diaphragm (F2.0 - 8 (W) / F3.3 - 8 (T)) / (F2.0 - 11 (W) / F3.3 - 18 (T) in movie recording )
Optical Zoom 3.8x
Focal Length f=5.1-19.2mm (24-90mm in 35mm equiv.) / (25-95mm in 35mm equiv. in movie recording)
Extra Optical Zoom (EZ) 4.5x (4:3 / 7M), 5.4x (4:3 / 5M), 6.7x (4:3 / under 3M)
Intelligent Zoom 5.0x
Lens LEICA DC VARIO-SUMMICRON / 10 elements in 9 groups / (3 Aspherical Lenses / 5 Aspherical surfaces)
2-Speed Zoom No
Step Zoom Yes
Optical Image Stabilizer POWER O.I.S. (Off / Auto / Mode1 / Mode2)
Conversion lens Compatibility Yes
Digital Zoom 4x / ( Max. 15.1 x combined with Optical Zoom without Extra Optical Zoom ) / (Max. 26.8 x combined with Extra Optical Zoom)
Focusing Area Normal: Wide/Tele 50 cm - infinity / Macro / Intelligent AUTO: Wide 1 cm - infinity / Tele 30cm - infinity
Focus Range Display Yes
AF Assist Lamp Yes
Focus Normal / Macro Quick AF On/Off (On in Intelligent Auto), Continuous AF On/Off / AF/MF Switchable, Manual Focus(Jog Dial), One Shot AF, AF Area Select, AF Tracking
AF Metering Face / AF Tracking / Multi (23pt) / 1pt (flexible / scalable)
Shutter Speed Still: 60 - 1/4000 sec / Movie Mode : 1/30 - 1/20,000 sec (1/8 - 1/20,000 sec on MF operation on Creative Movie mode) / Starry Sky Mode : 15, 30, 60sec.
Shutter Interval approx. 0.5 sec
Viewfinder (optional OVF/EVF)
Others
File Format Still Image: JPEG(DCF/Exif2.3) / Image with Audio: JPEG (DCF / Exif2.3) + QuickTime / Motion picture: AVCHD Lite, QuickTime Motion JPEG
ISO Sensitivity Auto / i.ISO / 80 / 100 / 200 / 400 / 800 / 1600 / 3200 / 6400* / 12800* (* by pixel mixed readout) / High Sensitivity (ISO 1600-12800)
Aspect Ratio 4:3 / 3:2 / 16:9 / 1:1
LCD Monitor 7.5cm (3.0") TFT Screen LCD Display (460K dots), AR Coat / Field of View : approx. 100% Wide Viewing Angle / AUTO Power LCD mode, Power LCD mode / High CRI (Color Rendering Index) LED backlight
Built-in-Flash Auto, Auto/Red-eye Reduction, Forced On, Slow Sync./Red-eye Reduction, Forced Off, Flash Synchro; 1st / 2nd / 0.8 - 7.2m (Wide/ISO Auto), 0.3 - 4.4m (Tele/ISO Auto)
External Flash Yes
Recording Media Built-in Memory, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Built-in-Memory Approx. 40MB
Microphone / Speaker Mono / Yes
Interface AV Output (NTSC/PAL, NTSC), mini HDMI, USB2.0 High speed
Viera Link Yes
HDMI output Video: Auto / 1080i / 720p / 480p(576p for PAL) / Audio: Mono
Power ID-Security Li-ion Battery Pack (3.6V, Minimum: 1250mAh) (Included) / AC Adaptor (Input: 110-240V AC) (Optional)
Battery life (approx.) 400 pictures (CIPA Standard)
Dimensions (W x H x D) 109.7 x 65.5 x 43.0 mm / excl. protrusions: 25.5 mm / (4.32 x 2.58 x 1.69 in / excl. protrusions: 1.00 in)
Weight Approx. 271g with Battery and SD Memory Card (0.61 lb) / Approx. 233g without Battery and SD Memory Card (0.51 lb)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Panasonic LUMIX DMC-LX...
