Peerless-AV Articulating Arm Wall Mount 39-75" LCD
£140.78
Delivery:
Standard: 1-3 working days
Key features
  • Extends 21.35" (542 mm) from the wall to swivel 90° left & right for the perfect viewing angle and retracts to 3.00" (76 mm) to save space
  • Locking tilt to lock the display at any angle from +15° to -5° with the ratcheting handle for optimal display positioning
  • Achieve perfect display leveling with ±5° of roll for post installation fine tuning
  • Universal mounting pattern fits a wide variety of displays with mounting patterns from 200 x 100 mm to 600 x 400 mm
  • The I-Shaped Adaptor plate’s innovative design helps avoid blocking connections on back of display
  • Integrated cable management protects, contains and conceals cables for a clean, professional installation
  • Hook-and-Hang installation means that the display is easily installed by a single person
  • Design is UL listed and tested to four times stated load capacity for the assurance of safety
  • Mounts to wood stud, concrete, cinder or breeze block and includes all necessary wall and display attachment hardware
Product codes
The Paramount series wall mounts provide versatile and multi-functional features. With PA750, extend the display up to 21.35" (542 mm) or fully-retract it to just 3.00" (76 mm) from the wall for the perfect viewing angle. The Hook-and-Hang system offers easy, one-person installation of the display. A ratcheting handle provides locking tilt capability for quick adjustments to the amount of tilt, reducing glare and optimizing the viewing angle. Integrated cable management protects, contains and conceals cables for a clean installation.
Peerless-AV Paramount PA750 - mounting kit
Mounting kit
Mounting Components
Articulating wall mount
61.9 cm x 7.6 cm x 42.5 cm
Adjustable Depth
7.6-54.2 cm
Tilt
-5° to 15°
Recommended Use
LCD / plasma panel
Recommended Display Size
39"-75"
Flat Panel Mount Interface
Up to 600 x 400 mm, from 200 x 100 mm
Max Load Weight
45.4 kg
Gloss black
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Peerless-AV Articulati...
£140.78
