Peerless-AV Articulating Wall Mount For 22"-40" Dis...
Peerless-AV Articulating Wall Mount For 22"-40" Displays
£91.50
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ideally suited for LCD screens up to 40" in size, up to 36kg (80lbs) in weight
  • Accommodates VESA 75, 100, 200x100 and 200x200 mounting patterns
  • One touch tilt allows screen to be angled forwards (up to 15°) or back (up to 5°) without the use of tools, screen pans left or right up to 90° in either direction
  • Roll adjustment allows the screen to be turned +/- 5° even when installed, ensuring perfect alignment
  • Double arm construction allows screen to be extended from 84mm to 513mm from wall (centred on wall plate)
  • UL/TUV safety certified
Product codes
From any angle, this wall arm mount reflects remarkable form and function. Extending the display up to 20.18" (513mm) from the wall and allowing for a full 180° of side-to-side motion for viewing in any part of the room. Fine-tuning of the installation is simple with its side-to-side display leveling features that help achieve installation perfection. This Full-Motion Plus Wall Mount also provides display centering on the wall plate and integrates a cable management system, centering the display on the wall when retracted and organizing and protecting the cables at all times. Designed and built in the USA, this mount maintains the same brilliant look as the entire SmartMount 700 Series line of Full-Motion Plus Wall Mount and Pivot Wall Arm Mounts.
Peerless SmartMount Articulating Wall Mount SA740P - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Tilt/pivot wall mount, articulating wall mount
36.4 cm x 55.4 cm x 25.8 cm
Adjustable Depth
7.7-55.4 cm
Tilt
-5° to 15°
Swivel
-90° to 90°
Adjustments
Roll, tilt, swivel, depth
3.3 kg
Recommended Use
LCD display
Recommended Display Size
22"-40"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36 kg
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Peerless-AV Articulati...
£91.50
