Peerless-AV LCD/Plasma Trolley with Metal Shelf 32" - 75...
Peerless-AV LCD/Plasma Trolley with Metal Shelf 32" - 75" max
Sorry but this product has been discontinued.
View used stock
Key features
  • Display and component shelf can be located anywhere along the column for perfect component placement and viewing height (up to 60" at center)
  • Integrated cable management protects, contains and conceals cables for a clean, professional installation
  • Maneuvers easily on 4" (102mm) swivel casters, two locking
  • Pre-assembled base provides rigidity, stability and quick assembly
  • Textured black powder coat finish helps hide finger prints and dust
  • Open frame display adaptor helps prevent display input interference
  • Universal display adaptor fits mounting patterns from 200x200mm to 600x400mm and allows mounting in landscape or portrait orientation
  • Type: Cart
  • Stock Status: In Stock, Used Stock
Product codes
The SR560M Flat Panel TV Cart has been redesigned to include all of the features you may need, making it perfect for any application. Mobility, appealing design, display height adjustment, pre-assembled base and UL certification ensure quick assembly while providing a ridged, but attractive, structure that fits into any d├ęcor.
The 4" castors make it easy to move from room to room while the UL certification ensures you that it can be done with safety in mind.
Product Description Peerless SmartMount Universal Flat Panel TV Cart SR560M - cart
Product Type Cart
Dimensions (WxDxH) 88.8 cm x 73.7 cm x 173.6 cm
Tilt -5°
Rotation 360°
Weight 30 kg
Recommended Use LCD / plasma panel
Recommended Display Size 32"-75"
VESA Mounting Interface 600 x 400 mm
Max Load Weight 68.2 kg
Colour Black
Manufacturer Warranty 5-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Damaged stock - Item is new but has packaging damage
Ref: 91VQ 037390
£96.58
product
Ref: 91VQ 037390
Accessories
Packaging
Functional
Software
Manuals
£96.58
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
