Peerless-AV SmartMount Universal Articulating Wall Mount For...
Peerless-AV SmartMount Universal Articulating Wall Mount For 37" to 55" Displays
£235.68
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Accommodates flat panels screens up to 52" in size, up to 41kg (90lbs) in weight
  • Universal mounting pattern accommodates mounting holes up to 686mm (h) x 439mm (v)
  • One-touch adjustment allows screen to be tilted forwards up to 15° or back up to 5° without the use of tools, full 180° range of motion for the best possible viewing angle
  • Double arm construction for extra strength and smooth motion - arms extend from 113mm to 697mm from wall
  • Roll adjustment allows the screen to be turned ±5°, together with 25mm (1") vertical adjustment even when installed for screen perfect alignment
  • UL/TUV safety certified
  • Type: Wall mount
  • Stock Status: In Stock
Product codes
From any angle, this wall mount reflects remarkable form and function. Extending the flat panel display up to 27.43" (697mm) from the wall and allowing for a full 180° of side-to-side motion for perfect view positioning of displays up to 52". Fine-tuning of the installation is simple with its side-to-side display leveling and 1" (25.4mm) of vertical adjustment features that help achieve perfection. This Full-Motion Plus Wall Mount also provides display centering on the wall plate and integrates a desirable cable management system, centering the flat panel display on the wall when retracted and organizing and protecting the cables. Designed and built in the USA, this mount maintains the same brilliant look as the entire SmartMount 700 Series line of Full-Motion Plus Wall Mount and Pivot Wall Mounts.
Product Description Peerless Universal Full-Motion Plus Wall Mount SA752PU - wall mount
Product Type Wall mount
Dimensions (WxDxH) 72.8 cm x 11.3 cm x 45.7 cm
Adjustable Depth 11.3-69.7 cm
Adjustments Tilt
Weight 15 kg
Recommended Use LCD / plasma panel
Recommended Display Size 37"-55"
VESA Mounting Interface Up to 600 x 400 mm
Max Load Weight 41 kg
Material Fused epoxy
Colour Gloss black
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Peerless-AV SmartMount...
£235.68
