Peerless-AV Tabletop TV Swivel Mount for Flat Panel TVs 32&qu...
Peerless-AV Tabletop TV Swivel Mount for Flat Panel TVs 32" to 47"
£121.14
Delivery:
Key features
  • Built-in swivel up to 360º allows for optimum viewing angle
  • Base stand bolts down for safety and security
  • Adjustable height allows for greater flexibility
  • Cable management internally through the mount and down through the mounting surface
  • Decorative base is aesthetically pleasing and hides desktop mounting hardware
  • Increased depth adapter plate allows for the jack pack protrusion on the backside of the TV
  • Security screws prevent tampering and theft
Product codes
The HP447 series flat-panel desktop swivel mount offers a secure, functional and sleek desktop surface mount for hospitality applications. It is designed to seamlessly connect to a variety of flat panel screen models while its deeper adapter plate allows for easy access to cable input connections. The built-in adapter plate is VESA 200 x 100 and 200 x 200 mm compliant and comes with security screws to deter tampering and theft. The mount provides more than just aesthetics and theft deterrence with its swivel range from 0º to 360º it delivers virtually any viewing angle within its diameter.
Peerless Desktop Swivel Mount HP447 - mounting kit
Mounting kit
Mounting Components
Desktop swivel mount
23 cm x 15.2 cm x 55.6 cm
5 kg
Recommended Use
LCD TV
Recommended Display Size
32"-47"
Flat Panel Mount Interface
200 x 200 mm, 200 x 100 mm
Max Load Weight
34 kg
Material
Steel, fused epoxy
Black powder coat
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Peerless-AV Tabletop T...
£121.14
