Peerless-AV Tru Vue TRVT561 Mobile Height Adjustable Trolley...
Peerless-AV Tru Vue TRVT561 Mobile Height Adjustable Trolley 32"-60"
£238.58
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Switch between landscape/portrait orientation without removing the display
  • Internal cable management
  • Hide cables to provide a tidy look
  • Smooth matt finish
Product codes
Documents
The TruVue TRVT561 provides a sleek and tidy mobile solution for 32"-60" displays. Complete with 2 heavy duty poles to display the screen at a maximum height of 1500 mm (59").
Its unique and convenient TV height adjustment is complimented by spring plunges providing 90-degree adjustments for landscape and portrait viewing, cable management, and 4 heavy duty braked caster wheels. The TRVT560 also comes with a spacious metal shelf for AV components.
  • Height Adjustable Max: 1530mm (60.2")
  • Universal VESA® 200x200 up to 600x400mm
  • Plastic component shelf for AV equipment
  • Internal Cable Management; hide cables to provide a tidy look.
  • Smooth matt black finish
  • Includes height adjustable VC Shelf
Height Adjustment
Adjusts & Locks Position
Creates a clean, professional installation while protecting and organising the cables
x4 Locking Caster Wheels
Provides stabilty
Peerless Tru Vue TRVT560 - cart
Cart
84.1 cm x 72 cm x 117.9 cm
Adjustments
Tilt
30 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-60"
Flat Panel Mount Interface
200 x 200 mm, up to 800 x 500 mm
Max Load Weight
45.5 kg
Powder coat, smooth matte black
Wheels Qty
4
5 years warranty
Resources
The following resources are available for the Peerless-AV Tru Vue TRVT561 Mobile Height Adjustable Trolley 32"-60"
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Peerless-AV Tru Vue TR...
£238.58
