Peerless-AV Twin Pole Universal Adaptor Large
£84.45
Delivery:
Standard: 1-3 working days
Key features
  • Large weight capacity
  • Universal VESA pattern from 300 x 200 to 600 x 400
  • Compatible with both MOD-FPMS single display and MOD-FPMD dual display mounts
  • Stock Status: In Stock
Product codes
With the universality of the components, configure your own perfect custom flat-panel display or projector mounting solution for any application. The Modular Mount line was developed with the professional AV installer in mind. Designed around a 2" (50 mm) diameter pole, the line is ideal for projects as well as for upgrading existing installations. The MOD-UNV2 provides additional screen fitment to the MOD-FPMS2 and MOD-FPMD2 with an adjustable VESA pattern from 300 x 200 to 600 x 400.
Product Description Peerless Modular Series Dual-Pole Large Universal Adaptor - mounting component
Product Type Mounting component
Mounting Components Universal adaptor
Dimensions (WxDxH) 62.4 cm x 2.1 cm x 42 cm
Adjustments Tilt
Weight 1.59 kg
Recommended Use LCD display
Recommended Display Size 46"-90"
VESA Mounting Interface 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 300 x 300 mm
Max Load Weight 96 kg
Colour Black powder coat
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Peerless-AV Twin Pole...
£84.45
