Peerless-AV Universal Flat Wall Mount for 32" to 40"...
Peerless-AV Universal Flat Wall Mount for 32" to 40" Displays
£36.64
32 in stock
Delivery:
Standard: 1-3 working days
Key features
  • For LCD screens up to 46" in size, up to 68kg (150bs) in weight
  • Universal mounting pattern accommodates mounting holes spaced up to 438mm (h) x 329mm (v) up to VESA 400x300 maximum
  • Safety tab ensures screen is securely attached to wall plate
  • Horizontal screen adjustment up to 150mm (6") for centring on wall
  • Low profile design holds screen 30mm from wall
  • UL/TUV safety certified
  • Type: Mounting kit
  • Stock Status: In Stock
Product codes
Ideally suited for medium/large LCD screens, the Paramount PF640 flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 30mm away from the wall.
Product Description Peerless PARAMOUNT Universal Flat Wall Mount PF640 - mounting kit
Product Type Mounting kit
Mounting Components Wall plate, bracket adapter
Dimensions (WxDxH) 48.9 cm x 3 cm x 34.9 cm
Weight 2 kg
Recommended Use LCD display
Recommended Display Size 32"-46"
VESA Mounting Interface 400 x 300 mm
Max Load Weight 45 kg
Material Fused epoxy
Colour Gloss black
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Peerless-AV Universal...
£36.64
