Philips 19S4QAB/00 19" 1280x1024 DVI VGA Monitor
£119.98
Select:
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • S Line
  • 19" (48.3 cm)
  • 1280 x 1024
  • Diagonal Size: 19in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
The Philips display using 25% recycled materials and PVC, BFR-free housing is ideal for eco-friendly productivity.
Product Description Philips S-line 19S4QAB - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19"
Panel Type IPS
Aspect Ratio 5:4
Native Resolution 1280 x 1024 at 60 Hz
Pixel Pitch 0.293 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 14 ms (typical); 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Textured black
Dimensions (WxDxH) - with stand 40.4 cm x 19.4 cm x 41.8 cm
Weight 3.2 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, C-Tick, BSMI, GS, SEMKO, CCC, TUV Ergo, PSB, DDC/CI, WEEE, CECP, cETLus
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 19S4QAB/00 19"...
£119.98
