Philips 200S4LYMB/00 20" 1600x900 5ms VGA Display Port M...
Philips 200S4LYMB/00 20" 1600x900 5ms VGA Display Port Monitor
£105.00
Delivery:
Key features
  • S Line
  • 20 (19.5"/49.5 cm diag.)
  • 1600 x 900 (HD+)
  • Diagonal Size: 20in
  • Max Resolution: 1600 x 900
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, VGA (HD-15)
Product codes
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
TrueVision is a proprietary Philips technology that uses advanced algorithm for testing and aligning monitor display which gives you the ultimate display performance. Philips ensures TrueVision monitors leave the factory finetuned with this process giving you consistent color and picture quality.
Product Description Philips S-line 200S4LYMB - LED monitor - 20"
Device Type LED-backlit LCD monitor - 20"
Aspect Ratio 16:9
Native Resolution 1600 x 900 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black with black stand
Dimensions (WxDxH) - with stand 47.9 cm x 22.7 cm x 38.4 cm
Weight 4.2 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, GS, SEMKO, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, EAC, cETLus
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 200S4LYMB/00 2...
£105.00
