Philips 200V4QSBR/00 20" 1920x1080 DVI VGA Monitor
£76.99
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • V Line
  • 20 (Viewable 19.53" / 49.6 cm)
  • Diagonal Size: 20in
  • Max Resolution: 1920 x 1080
  • Response Time: 20ms
  • Interfaces: DVI, VGA (HD-15)
  • Stock Status: In Stock
Product codes
Enjoy vibrant MVA LED pictures with this attractive, glossy design display. Equipped with SmartControl lite, it’s a great choice!
Product Description Philips V-line 200V4QSBR - LED monitor - Full HD (1080p) - 20"
Device Type LED-backlit LCD monitor - 20"
Panel Type MVA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.22 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 10000000:1 (dynamic)
Response Time 8 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Colour Black gloss textured
Dimensions (WxDxH) - with stand 47.9 cm x 20.1 cm x 36.9 cm
Weight 2.72 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV, CCC, PSB, DDC/CI, RoHS, Lead-Free, ETL, ISO 9241-307, WEEE, CECP, CEL, EPA, China RoHS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 200V4QSBR/00 2...
£76.99
