Philips 21.5" 1920x1080 5ms VGA DVI-D Black Monitor
£86.25
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • V Line
  • 21.5" (54.6 cm)
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DVI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £89.74
Save £1.50
Great LED images in vivid colours
Enjoy vivid LED pictures on this Philips display. Equipped with SmartControl lite, it's a great choice!
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
16:9 Full HD display for the best viewing experience
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colours.
LED technology for vivid colours
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
Easy display performance tuning with SmartControl Lite
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc with the mouse.
Mercury Free eco-friendly display
Philips monitors with LED backlighting are free of Mercury content, one of the most toxic natural substances, which affects humans and animals. This allows for an eco-friendly display throughout its life-cycle, from manufacturing to disposal.
Product Description Philips V-line 223V5LSB - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Colour Matte black, textured black
Dimensions (WxDxH) - with stand 50.3 cm x 21.3 cm x 37.6 cm
Weight 2.61 kg
Environmental Standards ENERGY STAR Qualified EPEAT Silver
Compliant Standards Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Accessories
Accessories
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 21.5" 1920x108...
£86.25
