Philips 22" LED 1680 x 1050 Monitor 16:10 1000:1 Vesa 10...
Philips 22" LED 1680 x 1050 Monitor 16:10 1000:1 Vesa 100 x 100
£111.14
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • V Line
  • 22" (55.9 cm)
  • Diagonal Size: 22in
  • Max Resolution: 1680 x 1050
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DVI, VGA (HD-15)
Product codes
Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with SmartControl lite, it's a great choice!
Product Description Philips V-line 220V4LSB - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Aspect Ratio 16:10
Native Resolution 1680 x 1050 at 60 Hz
Pixel Pitch 0.282 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Colour Textured black, glossy black
Dimensions (WxDxH) - with stand 51.2 cm x 21.3 cm x 41.6 cm
Weight 3.66 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, UL, BSMI, GOST, cUL, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, TCO Certified Edge
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 22" LED 1680 x...
£111.14
