Philips 221B6QPYEB 21.5" 1920x1080 IPS Monitor
Key features
  • AH-IPS LED gives brilliant images with vivid colors
  • Less eye fatigue with Flicker-Free technology
  • SmartImage presets for easy optimized image settings
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • Low bezel-to-table height for maximum reading comfort
  • Built-in stereo speakers for multimedia
  • USB Hub with 4 ports for easy connections
  • DisplayPort connection for maximum visuals
  • Zero power consumption with 0 Watt hard switch
Product codes
Get crisp images, efficient performance with PowerSensor saves energy! The Philips PowerSensor AH-IPS LED display using much post consumer recycled plastics and PVC, BFR-free housing is ideal for eco-friendly productivity.
Philips Brilliance B-line 221B6QPYEB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
Textured black
51.1 cm x 22.7 cm x 48.3 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays 6.0, cETLus
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 221B6QPYEB 21....
