Philips 221B7QPJKEB/00 22" 1920x1080 VGA HDMI DP Monitor
£165.00
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology for full colors and wide viewing angles
  • Edge-to-edge glass and narrow border for seamless appearance
  • SmartImage presets for easy optimized image settings
  • LowBlue mode for easy on-the-eyes productivity
  • Less eye fatigue with Flicker-free technology
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • Built-in stereo speakers for multimedia
  • USB 3.0 enables fast data transfers and smart phone charging
  • SmartConnect with DisplayPort, HDMI and VGA connections
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The Philips PowerSensor display using post-consumer recycled plastics and PVC, BFR-free housing is ideal for eco-friendly productivity.
Product Description Philips Brilliance B-line 221B7QPJKEB - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class A+
Energy Consumption per Year 23 kWh
Power Consumption (On mode) 16 W
Features 2.0 megapixel camera, USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black
Dimensions (WxDxH) - with stand 49 cm x 22 cm x 47.3 cm
Weight 5.08 kg
Environmental Standards TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, ICES-003, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, KUCAS, EPA, cETLus, Ukrain Safety, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 221B7QPJKEB/00...
£165.00
