Philips 221B8LJEB 22" 1920x1080 1ms HDMI VGA LED Monitor
£119.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • SmartImage presets for easy optimized image settings
  • 16:9 Full HD display for crisp detailed images
  • LowBlue mode for easy on-the-eyes productivity
  • Less eye fatigue with Flicker-free technology
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • EasyRead mode for a paper-like reading experience
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £123.47
Save £1.50
Get your best work done with the Philips 22" Full HD monitor. Crisp and vivid Full HD gives you the space and clarity to see your work. Features like height adjustment, Flicker-free and LowBlue mode make work easy on the eyes.
Product Description Philips B Line 221B8LJEB - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class A
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 21 W
Features USB 2.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Textured black
Dimensions (WxDxH) - with stand 50.4 cm x 20.6 cm x 47.7 cm
Weight 4.55 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV, TUV GS, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, EPA, cETLus, RCM, CU-EAC, BFR-free, Ukraine, PVC-free
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 221B8LJEB 22"...
£119.98
