Philips 221P6EPYEB/00 22" 1920x1080 VGA DVI Monitor
£205.52
Delivery:
Key features
  • SoftBlue technology protects eyes and maintains color
  • Less eye fatigue with flicker-free technology
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • IPS-ADS wide-view technology for image and color accuracy
  • SmartImage presets for easy optimized image settings
  • Built-in stereo speakers for multimedia
  • USB 3.0 hub for convenient access and fast charging
  • DisplayPort connection for maximum visuals
  • LightSensor optimizes picture quality
  • PowerSensor saves up to 80% energy costs
  • 65% post consumer recycled plastics with TCO Edge
Product codes
Designed for you, the Philips Brilliance monitor features SoftBlue LED technology to protect your eyes and deliver brilliant colorful images for maximum productivity.
Philips Brilliance P-line 221P6EPYEB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Power Consumption (On mode)
13.84 W
USB 3.0 hub
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured black
51.1 cm x 25.7 cm x 48.8 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, C-Tick, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, WEEE, TCO Certified Edge, CECP, TCO Displays 6.0, cETLus
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 221P6EPYEB/00...
£205.52
