Philips 221S6LCB/00 22" 1920x1080 DVI VGA Monitor
Key features
  • S Line
  • 22 (21.5"/54.6 cm diag.)
  • Full HD (1920 x 1080)
Product codes
Philips Flicker Free technology applies an ultimate solution to regulate brightness and reduce flicker for more comfortable viewing. LED allows for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
This LED features the SmartImage - an exclusive advanced Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. Philips advanced video processing combined with unique extreme dimming and backlight boosting technology results in vibrant images. The SmartErgo base is a monitor base that delivers ergonomic display comfort and provides cable management. SmartPower is an artificial intelligent technology which dynamically analyzes the content of the screen image to achieve power saving.
Philips S-line 221S6LCB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Textured black
51.1 cm x 22.7 cm x 48.3 cm
4.64 kg
FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, J-MOSS, E-Standby, CECP, EPA, TCO Displays, cETLus, RCM, CU-EAC
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 221S6LCB/00 22...
