Philips 221S6QYKMB/00 22" 1920x1080 DVI VGA Monitor
£175.03
Delivery:
Key features
  • AH-IPS display for brilliant images with vivid colors
  • Less eye fatigue with Flicker-free technology
  • SmartImage presets for easy optimized image settings
  • SmartContrast gives enhanced rich black details
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • Low bezel-to-table height for maximum reading comfort
  • Webcam with mic to connect and collaborate
  • Built-in stereo speakers for multimedia
  • DisplayPort connection for maximum visuals
  • Recycled material with EPEAT Gold
  • SmartPower enables significant power saving
Product codes
The Philips ergonomic LED display using recycled materials and PVC, BFRfree housing is ideal for eco-friendly productivity. This improved display uses advanced AH-IPS panels resulting in superior color reproduction, response time and power consumption. AHIPS panels show consistent color even at 178 degrees wide angles and in pivot mode. With remarkable performance, AH-IPS is optimally suited for applications demanding color accuracy and consistent brightness at all times like photo retouching, graphics applications and web browsing.
Philips S-line 221S6QYKMB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Power Consumption (On mode)
17.1 W
Microphone, 2.0 megapixel camera
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured black
51.1 cm x 22.7 cm x 38.4 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VCCI, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, CECP, EPA, TCO Displays, cETLus, RCM, FCC Part 15 Class B
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 221S6QYKMB/00...
£175.03
