We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Our S Line monitor delivers business efficiency. Features like Flicker-free and LowBlue mode make work easy on the eyes and increase your productivity.
Product Description | Philips S-line 221S8LDAB - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class E | Power Consumption (On mode) | 16.3 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC (CIE 1931) | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating, Haze 25% | Voltage | AC 120/230 V (50/60 Hz) | Colour | Textured black | Dimensions (WxDxH) - with stand | 50.4 cm x 20.8 cm x 39.5 cm | Weight | 2.8 kg | Environmental Standards | TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV, TUV GS, VCCI, BSMI, ICES-003, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, MEPS, CEL, EPA, cETLus, CU-EAC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | TN |
Pixel Per Inch | 102 |
Vertical Refresh Rate | 48 - 76 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, sRGB colour management, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, Adaptive-Sync technology, EasyRead |
Dimensions (WxDxH) | 50.4 cm x 20.8 cm x 39.5 cm - with stand |
Weight | 2.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DVI-D (HDCP) , HDMI , VGA , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+25 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | Audio cable , VGA cable , HDMI cable |
MTBF | 70,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16.3 kWh/1000h |
Power Consumption (Typical) | 14.2 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.4 cm - depth: 20.8 cm - height: 39.5 cm - weight: 2.8 kg , Without stand - width: 50.4 cm - depth: 4.7 cm - height: 30.4 cm - weight: 2.46 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 56 cm |
Shipping Depth | 13.8 cm |
Shipping Height | 45.2 cm |
Shipping Weight | 4.41 kg |
Environmental Standards | |
TCO Certified | TCO Certified Edge Displays, TCO Certified Displays 9 |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
