We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
A sturdy, water-resistant and dust-resistant, anti-glare touchscreen monitor for flexible use anywhere, with articulating stand to fit angles you need. Offering simple and intuitive use across applications, greatly boosts productivity.
Product Description | Philips B Line 222B9T - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" - touchscreen | Energy Class | Class D | Energy Consumption per Year | 29 kWh | Power Consumption (On mode) | 12.7 W | Features | Stylus, USB 3.1 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC (CIE 1931) | Input Connectors | HDMI, DVI-D, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating, Haze 25% | Voltage | AC 120/230 V (50/60 Hz) | Colour | Textured black | Dimensions (WxDxH) - with stand | 51.5 cm x 22.7 cm x 39.4 cm | Weight | 7.46 kg | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, EPA, CU-EAC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Built-in Devices | USB 3.1 hub |
Panel Type | TN |
Pixel Per Inch | 102 |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
OSD Languages | Multilingual |
Features | Sync on Green, Lead-free, SmartContrast, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, EasyRead, sRGB Mode |
Dimensions (WxDxH) | 51.5 cm x 22.7 cm x 39.4 cm - with stand |
Weight | 7.46 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | Stylus - touchscreen |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , DisplayPort , HDMI , USB 3.1 , USB 3.1 (fast charging) , USB upstream , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | SmartStand |
Included Accessories | Stylus (black) |
Cables Included | 1 x VGA cable , 1 x HDMI cable , 1 x USB-A to USB-B cable , 1 x audio cable |
MTBF | 70,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 12.7 kWh/1000h |
Power Consumption (Typical) | 15 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Philips SmartControl |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (highest position) - width: 51.5 cm - depth: 22.7 cm - height: 39.4 cm - weight: 7.46 kg , Without stand - width: 51.5 cm - depth: 4.5 cm - height: 31.7 cm - weight: 4.17 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 57.5 cm |
Shipping Depth | 16.1 cm |
Shipping Height | 42 cm |
Shipping Weight | 9.97 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
