Philips 222B9T 24" 1920x1080 2ms DVI HDMI LED Monitor
£230.50
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • SmoothTouch display for natural, fluid touch response
  • Stylus for fluid and accurate performance with more control
  • Monitor front surface meets IP54 for water & dust resistance
  • 16:9 Full HD display for crisp detailed images
  • SmartContrast for rich black details
  • LowBlue mode for easy-on-the-eyes productivity
  • Less eye fatigue with Flicker-free technology
  • EasyRead mode for a paper-like reading experience
  • HDMI ensures universal digital connectivity
  • USB 3.1 high speed data transfer
  • DisplayPort connection for maximum visuals
  • SmartStand with adjustable angles, boosts productivity
  • VESA mount allows for flexibility
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
A sturdy, water-resistant and dust-resistant, anti-glare touchscreen monitor for flexible use anywhere, with articulating stand to fit angles you need. Offering simple and intuitive use across applications, greatly boosts productivity.
Product Description Philips B Line 222B9T - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22" - touchscreen
Energy Class Class A
Energy Consumption per Year 29 kWh
Power Consumption (On mode) 20 W
Features Stylus, USB 3.1 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 50000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating, Haze 25%
Colour Textured black
Dimensions (WxDxH) - with stand 51.5 cm x 22.7 cm x 39.4 cm
Weight 7.46 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, EPA, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 222B9T 24" 192...
£230.50
