We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Our S Line monitor delivers business efficiency. A wide-view IPS display with SoftBlue technology is great for easy-on-the-eyes productivity. The height-adjustable, frameless display allows for tiling multiple monitors for an expanded view.
Product Description | Philips S-line 223S7EYMB - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class E | Power Consumption (On mode) | 16.5 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Contrast Ratio | 20000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 68% NTSC | Input Connectors | VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black, textured black | Dimensions (WxDxH) - with stand | 49 cm x 20.2 cm x 45.5 cm | Weight | 4.51 kg | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, ICES-003, SEMKO, PSB, WEEE, EPA, cETLus, ISO9241-307, CU-EAC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 9300K, 5000K, 6500K, 7500K, 8200K, 11500K |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, sRGB colour management, SmartContrast, SmartImage, Low Blue Light Mode, Flicker Free technology, SoftBlue Technology, EasyRead |
Dimensions (WxDxH) | 49 cm x 20.2 cm x 45.5 cm - with stand |
Weight | 4.51 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DisplayPort , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 350 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16.5 kWh/1000h |
Power Consumption (Typical) | 20.2 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 49 cm - depth: 20.2 cm - height: 45.5 cm - weight: 4.51 kg , Without stand - width: 49 cm - depth: 4.5 cm - height: 29.6 cm - weight: 2.63 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
