Philips 223V5LSB2/10 21.5" LED 1920x1080 VGA Black
£69.88
Delivery:
Standard: 1-3 working days
Key features
  • V Line
  • 21.5" (54.6 cm)
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £73.37
Save £1.50
Enjoy vivid LED pictures on this Philips display. Equipped with SmartControl lite, it's a great choice!
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
Product Description Philips V-line 223V5LSB2 - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 200 cd/m²
Contrast Ratio 600:1 / 10000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors VGA
Display Position Adjustments Tilt
Colour Textured black, black hairline
Dimensions (WxDxH) - with stand 50.3 cm x 21.3 cm x 37.6 cm
Weight 2.61 kg
Environmental Standards ENERGY STAR Qualified EPEAT Silver
Compliant Standards Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Accessories
Accessories
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 223V5LSB2/10 2...
£69.88
