This brilliant wide view display offers vivid colors and crisp details wrapped in an elegance inspired design for a light and fresh face in any home or office.
Philips E-line 237E7QDSB - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, HDMI (MHL)
Display Position Adjustments
Tilt
Glossy black
53.2 cm x 21.3 cm x 41.4 cm
3.21 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV, VCCI, C-Tick, SASO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, KUCAS, CECP, EPA, TCO Displays, cETLus
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
23"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Security Slot Type
Kensington security slot
17.94 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 21.3 cm - height: 41.4 cm - weight: 3.21 kg , Without stand - width: 53.2 cm - depth: 4.9 cm - height: 32.6 cm - weight: 2.96 kg
