Philips 24" Brilliance LCD Monitor S-Line Full HD SmartI...
Philips 24" Brilliance LCD Monitor S-Line Full HD SmartImage Black
£146.50
Select:
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • S Line
  • 24" (61 cm)
  • Full HD display
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DVI, VGA (HD-15)
Product codes
The Philips ergonomic LED display using 25% recycled materials and PVC-BFR free housing is ideal for eco-friendly productivity.
LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
Product Description Philips S-line 241S4LCB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.276 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black with black stand
Dimensions (WxDxH) - with stand 56.5 cm x 22.7 cm x 40.3 cm
Weight 6.3 kg
Environmental Standards TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 24" Brilliance...
£146.50
