Philips 24" LCD Monitor with SmartControl Lite
£117.76
Delivery:
Key features
  • V Line
  • 24" (61 cm)
Product codes
Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with SmartControl lite, it's a great choice!
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
Product Description Philips V-line 246V5LSB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.277 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Colour Textured black, glossy black
Dimensions (WxDxH) - with stand 56.5 cm x 23.8 cm x 43.5 cm
Weight 4.65 kg
Environmental Standards ENERGY STAR Qualified EPEAT Silver
Compliant Standards Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 24" LCD Monito...
£117.76
