Philips 240B4QPYEB/00 24" 1920x1200 DVI VGA Monitor
£209.98
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • B Line
  • 24" (61 cm)
  • WUXGA (1920 x 1200)
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 15ms, 15ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
The Philips PowerSensor LED display using recycled materials and PVC, BFR-free housing is ideal for eco-friendly productivity.
Product Description Philips Brilliance B-line 240B4QPYEB - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 33 kWh
Power Consumption (On mode) 22.3 W
Features USB Hub
Panel Type Plane to Line Switching (PLS)
Aspect Ratio 16:10
Native Resolution 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black with black stand
Dimensions (WxDxH) - with stand 55.5 cm x 24.4 cm x 55 cm
Weight 6.9 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 6.0, cETLus
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 240B4QPYEB/00...
£209.98
